Adjusting track with wheels.
afret
L3901, MX5800, U55-4
May 7, 2015
167
North Idaho
If your wheels are adjustable to increase or decrease the track, if you set it for maximum track width for stability, would it increase the stress on axle components and increase the chance of parts failure?
Ramos
1870-1, LA203A, RCK54
Feb 25, 2016
463
Sherman County, Oregon
Technically, yes. However, one would hope that the strength needed is engineered into the machine as long as it is operated with reasonable care and the width does not exceed factory specs.
5,335
2,009
Years ago it was common for people to turn the wheels around to make them wider and more stable. Seen lots of knuckle/kingpin seals leaking, and failed hub bearings and seals. Local kubota guy swore that "widening" them was the root case as they were not designed to handle the extra stresses on the knuckles and hubs. Speaking of 4x4 stuff only, and under 50hp. I think all the newer stuff will be fine, they've come a LONG way since the 1990's :)
Tooljunkie
May 13, 2014
4,150
This opens up a can of discussion. Widening front wheel stance does little or nothing for stability, it is hard on front end components. Old or new machines.
Widening the rears,adding ballast are two things to improve stability. Even a few inches will make a noticeable difference.
afret
May 7, 2015
167
North Idaho
Thanks for all the replies. I guess it's best to leave the front alone and widen the back. :)
7,408
Some of the larger L's, MX's, and M's offer adjustable front wheels, but most do not, and it is not advisable to do so if it didn't come from the factory with the option.
Now as far as stability, you can very little if any stability from a wider front as the front axle pivots, almost all the stability come from a wide low back end. ;)
bucktail
Jun 13, 2016
1,252
189
MN
I don't know my Kubota's that well, but on domestic brands, the adjustable front was to match row width for cultivating, spraying, picking rock etc. on row crop after emergence. They could also be run out to better straddle a windrow when used with a baler without an offset pickup.
Tooljunkie
May 13, 2014
4,150
Many of those adjustable front ends extended the axle tube. Wheels and spindles had the same relationship to one another.
