The MX5800 has an option for draft control. Would that be useful in any way in a non farming situation like maintaining a gravel driveway?
Sounds as if your tractors rockshaft(3 pt) piston seal is leaking which will probably require R&R of rockshaft housing.I don't know what a draft control is but if it stops the 3pth from creeping down that would be great.
My old tractor creeps down really fast even with the knob locked.
I am not sure how I would go about fixing that?
Draft control was designed for plowing to keep a constant load on engine when plow encounters tough soil and increase traction. If height or depth control is desired I suggest not to utilize draft control. Tasks such as mowing or operating a blade should be performed not utilizing draft control. Also the hole one attaches center link to bracket on tractor affects draft sensitivity. Normally the lower the hole in the bracket the more sensitive the "draft control"The MX5800 has an option for draft control. Would that be useful in any way in a non farming situation like maintaining a gravel driveway?
I think you may have draft control confused with position control. Position control keeps the 3 pt at whatever height you set it with the control lever. Draft control will lift the 3 pt when a plow is pulling too hard.My previous tractors did not have draft control. I ended up many times setting the height I wanted and then shutting off the valve to the 3PH to lock it in place while brush hogging. On one tractor, I'd actually chain the 3PH up to keep it from drifting down while mowing.
Now, with draft control, I have not run into that problem.
If I have to pick the implement up at the end of a pass in order to turn around, I know where to place it for the next pass. Much easier.
I didn't know what draft control was, but I like it.
I do believe I did have them confused. The position control came standard with my tractor. Thanks for helping me out.I think you may have draft control confused with position control. Position control keeps the 3 pt at whatever height you set it with the control lever. Draft control will lift the 3 pt when a plow is pulling too hard.
OP: I don't see a need for draft control unless it's a 100% farming tractor. Just me personally - and I don't use a bottom plow just a subsoiler and chisel plow - but with no more than I do I prefer to control the height myself so I know the areas I need to work more. Typically it's when using the subsoiler and it encounters roots or rocks.
Agree, we used it farming, but with regular use it is not needed, it came stock on our M8540, but I didn't get it on our L5740.Thanks everyone. I guess I don't need it in my situation.
