Wire harness for ROPS lights
5,441
I dont know how it would work Im pretty much old school and hard wire everything,, if you go this route please post back and let us know how it works,, I may have to re think things :D
3,049
OC455
BX2350 LED ROP, FEL, Belly mower,modified snow blower, pole boom, middle plow
Sep 30, 2016
161
12
Rome NY USA
Remote control is fine and dandy......until you lose the remote! OR the batteries decide to die the ONE tie you realllllly need to use it!:D
I am like Skeets, old school - but willing to change!:eek::)
Here is another route:
https://www.amazon.com/MICTUNING-MI...5495110&sr=8-7&keywords=12+volt+switch+wiring
I'm just going to put the fob on to the key ring with my tractor keys anyway. :D
I'm not to keen on drilling holes into the tractor I guess...:cool:
Finding a square shaped U-bolt is a PITA. Either they are too long or the are too wide for what I want. Might have to bend some brackets for what I want.
OC455
Sep 30, 2016
161
12
Rome NY USA
Look at the bolt-on stake pockets. They fit perfectly around my rops.
I ordered the bolt on stake pockets and they're perfect for the ROPS on the BX2350. I am going to make the flat brackets to bolt up to the stake pockets. I decided to go with two 12inch LED light bars instead of four 18watt cube style lights. I figured it would be easier to wire up.
http://www.ebay.com/itm/201637993135?_trksid=p2057872.m2749.l2649&ssPageName=STRK:MEBIDX:IT
I painted the stake pockets ROPS grey and will do the same with the mount brackets.
I'm still going to use the wireless remote wiring harness. Found a nice one that should work well. Waiting for the lights and harness to arrive.
OC455
Sep 30, 2016
161
12
Rome NY USA
Got the wiring harness mocked up and my LED light bars mounted to the ROPS. I think they look pretty good so far.
hiho silver
Orange Tractor L3901
Nov 28, 2016
50
Midwest US
I stopped by the local Case IH dealer and had no problem getting 3" x 3" x 1/2" square u-bolts. Fit perfectly on the rops to attach my homemade light brackets.
rabbott
BX2380
Dec 19, 2016
11
Springfield
Where are you getting your power from?? I want to hook up a shute motor for
my blower but can't find a power source other than the 12v plug.
10,866
If your working with a blower chute, you need to go to the battery to get power, none of the stock wiring will handle the load of that motor. ;)
