Billdog350
Kubota L3710 HST,L2230A QT,forks,Takeuchi TB125, 60" Luck Now pto Snowblower
A friend has a 1yr old B2620, I serviced it a few months ago for him and it was running fine. Oil change, UDT filters, fuel filters, etc.
He ran the machine for a few months with zero issues, then he got in a sticky situation on a side hill and tipped the machine on its side. He shut it down as it was rolling over before bailing.
Once he got it upright, he started it and it smoked a lot (as can be assumed from laying on the side). However, the issue is that it now smokes a whitish blue smoke upon startup (he's started it and used it a half dozen times since). It smokes more upon startup and cleans up once its running, but at WOT it will smoke a little as well. Never did this before the tip over.
My guess is that the quick shutdown combined with the machine being on its side somehow impacted the head/headgasket. Its possible the oil leaking past the rings while on its side caused it to hydrolock a little upon starting and it impacted the head/headgasket.
Any thoughts or have any of you seen this? The machine has LOW hours on it and I'm guessing its out of the Kubota warranty by now...
He'd rather not rip it apart for a little smoke, but then again preventing further damage is the right thing to do.
