I have recently purchased a M7060 tractor with a cab and would like to get a radio for it. Do I buy it from Kubota or do you have a better suggestion?
Thanks...
Thanks...
Thanks...
I don't think headphones will work as on the radio has Bluetooth for input connections. There is most likely an adapter that would convert a speaker signal to a Bluetooth signal for headphones that work off of 12v power.Does anybody know with a bluetooth radio can you connect bluetooth headphones to listen to the radio? I tried this and can not get it paired. My phone pairs though and i can listen to music from my phone or hear the phone ring. Thanks
You shouldn't have any issues pairing your headphones. You may need to get either radio and/or headset into a "paring mode" (manufacturer dependant check manual) The radio should prompt you for a code which usually defaults to be "0000"Does anybody know with a bluetooth radio can you connect bluetooth headphones to listen to the radio? I tried this and can not get it paired. My phone pairs though and i can listen to music from my phone or hear the phone ring. Thanks
