BX 2370 Wheel Weights
DavyW
BX2370, Z422 and L2501
Aug 29, 2016
26
Newport, NC, USA
I am interested in adding wheel weights and liquid to my BX2370...Where is the best place to buy the wheel weights?
thanks..Davy
2,672
thanks..Davy
Loading the tires is simple and easy...WWF might cost ya $25. The weights on the other hand will cost a plenty, whatcha got on the rear end? If'n I needed extra weight on the rear, and my rear was empty most of the time, I would make my own ballast box, that way I can take it off when I do not need it and 3 point it when I do!;):)
TripleR
Sep 16, 2011
1,911
SE Missouri
I got mine from my dealer, you might check with EA Attachments or Lonestar.
3,653
I filled my rears on my 2360 and it did make a world of difference, gave me about 45 pounds per wheel, now that might not seem like a lot but trust me it is. Found at a yard sale weights off an old Cub,, they bolted up I just needed some reallllly long bolts paid I think 35 bucks they are 45 pounds each and my fat old arse on there ,,, well I got all the weight I need,, Also you can take a small rubber made tub and put a pipe through it, so it will fit the 3pt and fill with cement,, and you can take it off when you dont need it.. Look around in here theres a lot of ideas on how to add weight,, and if you can find a bar bell set at a yard sale you can add then to the 3pt of fine a metal suppler and have them cut you out a couple and drill holes for bolts,,, I know of an old timer that took 2 5gallon buckets figured out where the bolt holes were and filled them with cement they wobbled a bit when he drove it but they were cheap and easy
edwardsonmark
39
US
Here is not a very good picture of mine. Came off a 445 John Deere and are same ones offered for 1025 r. They are spendy and weigh about 175# per wheel. Luckily I got them off the Deere before trade in!
PS don't mind my daughter's frilly cup in the pic!
3,653
Those wheel weights are like everything on a deeeeerrrr dead weight,,,lol,,, OK Im sorry if I upset and green fans,,,,, ahh no wait,,nope Im not :D
2,672
kinda like someone told me a long while back .....
taking out the trash!
DavyW
Aug 29, 2016
26
Newport, NC, USA
Thanks guys for the feedback..... I am going to try filling the tires first and make a ballast box for the back....
This is a great site and I enjoy the sharing of information... I am a new tractor owner and have a lot to learn.
Thanks
3,653
Welcome to the orange Dave,, and there is more info in here than you can shake a stick at, plus some good natured ribbing once in a while:D
