ZL1500dt broken axle
Lotsarocks
L1500DT zen noh, 4' brush hog, ford 4' finish mower, 6' rock-landscape rake
Feb 9, 2016
Midway, Ar.
Hi All
This is my first post to the forum.
I was brush hogging and the right front wheel took off across the field on its own. The axle broke between the wheel and housing. I found a used axle online (Kubota wants $1000 for a new one). It is off a L185dt. Will this fit my ZL1500dt? Also do I need any other parts to install it?
Thanks for any and all help.
8,546
This is the man to talk too, to answer your question. He just did a complete restore on his :D
http://www.orangetractortalks.com/forums/showthread.php?t=26492
The l1500 is actually a mixture of a couple different tractors. And I don't believe the front end is the same as the l185. But send bill a pm if he doesn't respond to your post here and he should be able to point you in the right direction :D
billrigsby
Mar 17, 2015
1,039
217
Florissant CO USA 8213'
www.facebook.com
Lotsarocks
Feb 9, 2016
Midway, Ar.
Thank you billrigsby,
The drawings help a lot. I fond a axle online it should be here by the end of the week.
Are the bearings pressed on axle? I have not taken it apart yet because of were it is setting.
I'll let yall know when I get it back together.
Steve
