Bx2350 4wd question
08quadram
bx2350d; Taylor Way 48" tiller; Farm King 50" snow blower
Apr 28, 2014
289
strawberry point, ia
Im trying to decide if this is normal. When i put my little work borse in 4wd, I've noticed that the rear end seems to lock the differential. Is this supposed to be normal? Seems like not. Seems to push the front some when turning corners even though the fronts are turning(pulling). On gravel the inside wheel ripps up the rock. When in 2wd I dont have this issue. When i try and use the diff. lock manually it doesn't seem to lock in. Pedal won't go all the way down to the floor boards.
Thoughts?
Mike
5,209
Mike -
If it feels like your tractor has the diffy lock engaged while in 4wd, it means you should disengage 4 wd. The tractor has too much grip to warrant 4wd.
To continue that way can cause drivetrain damage.
I normally run mine in 4wd all winter while snowblowing. But if the road out front is bare, I often will take it out of 4wd to make the loop out of/back into the driveway.
08quadram
Apr 28, 2014
289
Thanks for the onput. Gravel road isn't too much grip. Or grass for that matter. My conern is that the inside wheel is locked with outside wheel. 2wd doesn't do this. Wondering if this is supposed to be normal. usually i only use 4wd in winter and when using FEL digging or moving dirt.
Mike
2014 Chrysler 300
1970 VW beetle
2006 Ford Freestyle
2008 Ram 1500 5.7 Hemi
2013 Passport 2920bh GT
BX2350
and a bunch of other crap
hodge
Nov 19, 2010
2,903
450
Love, VA
Mike
2014 Chrysler 300
1970 VW beetle
2006 Ford Freestyle
BX2350
Engaging the 4 wheel drive has nothing to do with the locking mechanism in the rear axle. I believe what you are experiencing is driveline tension, where you have enough traction that neither the front tires nor the rear are slipping any, releasing tension. That isn't uncommon.
5,559
Mike, if your rears where locked together you would not be able to turn. Your tractor would only go straight forward...or backward.
08quadram
Apr 28, 2014
289
An open rear should still allow the inside rear to turn slower than the outside rear. Usually it is the front drive that makes my truck jumpy
Mike
2014 Chrysler 300
1970 VW beetle
2006 Ford Freestyle
BX2350
bucktail
Jun 13, 2016
1,251
189
MN
Mine doesn't lock them in 4wd. I was pulling trees last weekend and even in 4wd you had to hold down the diff lock to get both rears to spin together. It doesn't turn very well in 4wd though...
5,209
Mike - My apologies, I don't think I explained it well, but Hodge did a much better job.
Even though your front isn't jumpy like your truck, essentially it's a similar deal.
Your tractor has too much traction in 4wd on the gravel or grass. Fronts don't have the differential ability like the rears when you turn.
Your truck, like the last 6 of mine, will talk to you a little when turning if in 4wd when it shouldn't be. Your BX is doing the same thing. You can feel it on the steering wheel.
My BX2360 does NOT want to be in 4wd on dry grass or packed gravel if turning much. I think that what I'm on needs to be greasey to warrant 4wd. Same with my truck. Otherwise, tractor or truck wants to push, and not turn. Same-same.
Has nothing to do with the rear differential, its actually the fronts not wanting to play with each other while turning. It does feel similar, but if your diffy lock was engaged, she would complain much more about turning, and taking it out of 4wd wouldn't change it.:(
I hope this makes more sense. Certainly wish you the best!
For the other guys that responded to your question, if I missed it entirely, please correct me. Won't be the first time I missed the boat!:eek:
5,209
Mike - afterthought -
I've wanted to put front tire chains on for winter since I've had my tractor. I snowblow some steep areas.
Several guys have with success.
The only reason I haven't is because some say they provide too much front-wheel traction, and may cause damage.
Same idea as running 4wd when you're on firm ground.
CountryBumkin
BX2370 w/LA243, Bucket, Grapple, QA Pallet Forks, 60" MMM, rear blade & rake
Sep 27, 2015
568
Central FL
You can use the front chains in 2wd to help with steering control on snow/ice. Then if stuck, just engage 4wd long enough to get unstuck.
08quadram
Apr 28, 2014
289
Thanks everyone. I understand the mechanics of 4wd operation, but I cannot remember my bx acting that way when I bought it. I had a hard time telling if the 4wd was actually working.
Mike
2014 Chrysler 300
1970 VW beetle
2006 Ford Freestyle
BX2350
Guv
24
Seguin Texas
What if you jacked the rear off of the ground (in 4wd) and rotate one of the rear tires? My cars with a posi trac or limited slip would turn both tires in the same direction. An open rear end spins the other tire in the reverse direction.
