I have an L4701 with 26.5 hrs. I Started the tractor this PM to complete mowing and as I brought the RPM into the recommended range for activating the PTO, the engine shut down. I noted error codes P0606, P0629, P0627, and P087 codes. I immediately shut down, popped the hoof and noted one(40 amp) of the two fuses in the fuse block (battery isolation) was not properly seated. I seated the fuse and did a restart. I brought the RPMs into the range for the PTO and all seems fine but the codes won't clear.
Any help would be appreciated!!!
