I have a B7100 that I recently purchased that had been sitting for awhile. The left brake is stuck and I determined that it is the shaft that goes beneath the tractor and allows the pedal on the right to actuate the lever going to the left brake. I have removed both brake pedals on right side of tractor and linkage for clutch on left that runs on same shaft. I think the shaft should drive out to the left (clutch) side of the tractor, but I cannot get it to budge. I have sprayed on lubricant, but there is limited access.
Is there anything holding this shaft in place that I am overlooking?
Thanks,
Thanks,
