NoJacketRequired
Front axle is a little low on fluid. Bottom ends of the vertical portion of the shaft are weeping a little fluid so I suspect this has been going on for a while and nobody has bothered to top up the axle.
The manual says to use either the same fluid as the hydrostatic transmission (Super UDT I seem to recall) or 80W90 gear oil.
I'm tempted to drain whatever is in there and install Valvoline synthetic 80W90 because it's less likely to be as drippy as hydraulic oil would be, but that's only my uninformed supposition.
What say the great experts here - hydraulic fluid or 80W90, and why?
