Ive got an old Case TL-100 walk behind trencher that broke a gear inside the transaxle so its basically junk. The engine is very old and tired, but the digging arm and chain/teeth are in good useable condition. SO I have decided to get rid of the engine, transaxle, and adapt it to receive some 3 point arms and a PTO drive so I can run it behind my BX2200.
The old trencher is completely non-hydraulic. Everything is done via belts/pulleys/chains and the digging arm goes up & down via a hand crank.
Ive got to get PTO power to the trencher and turn the power output 90 degrees to interface with the rest of the pulley system. I think I would have to use a gearbox and I have a small brushhog and also a belly mower to scavenge parts (Gearboxes) from if need be.
Any suggestions? I plan on using a combination of the hand crank and the 3 point lift arms to set digging depth. Fabricating hydraulic controls into it may turn it into more of a project than I would like to make out of it, although it is an option and I could tap into the FEL controller to operate it but it would be even better with secondary controls.
I have seen what tractor supply stocks for sprockets/gears/hydraulic cylinders/pto driveshafts and parts/etc and feel like I could get 90% of what I need from there.
What online sources are you guys finding good deals and good selection on?
I would appreciate and consider ANY and all input. I'll post pictures a little bit later.
I would RATHER setup my B6200 to do this but its got a manual transmission and I cant slow the tractor down enough to make it work. The BX with the HST is going to be my only option right now.
