I have a BX at the ctg, and last weekend finally got around to removing the fender to trace a long standing, slow fuel leak on my BX. Thought it would be the fuel sender flange, the tank was damp half way under the seat, but turned out to be from the back lower left fuel hose. Man diesel can sure creep.
The hose is not leaking, the fitting of the hose to the hose barb is not leaking, it seems to be coming from where the barb goes into the tank. Question, is the hose barb and tank all one piece? It looked like the other end of the hose barb screwed into the tank? Whatever the case it is all ABS. Did not want to open that can of worms till I had a checked here, asked the dealer, and had supplies to fix. Dealer says it's all one piece.
If it's just a barb, I can tighten with some sealant. If it's all one piece (pr was until the hose barb seperated from the tank) is there any glue I can use that will stand up to diesel? I have also heard about welding ABS, but not sure there is enough wall thickness or I am able to do it?? It's ~300 to replace the whole tank.
