Many years ago I hit some kind of rock that resulted in a bent fan blade and one of the augers. I would have expected one of the shear bolts to break, but neither the fan's or auger's broke. What did break was the spring pin holding the small drive sprocket to the shaft. That first time I took it to the dealer for repair and ended up with a hardened steel pin with a cap on one end and a washer and cotter pin on the other end, but not as tight a fit as a spring pin.
This worked for about four years, but I suspect through sheer wear, the soft steel cotter pin wore out and the pin was thrown. The down side of this fix was due to the slop in the pin, the two holes in the gear got worn and elongated. I was able to repair it twice with the correct spring pin, but though the hole in the shaft was still tight, the elongation of the holes in the gear along with the resulting slop, resulted in wearing out the ends of the spring pins.
After this last failure, fortunately as I was finishing the last blowing for the season, I decide to replace shaft and gear. Even though the Parts Manual shows the gear as being attached to the shaft with a spring pin, it is only sold as a single assembly. I ordered a replacement and am guessing that there were other such failures since the new assembly has the gear welded to the shaft rather than being attached via a spring pin.
This then brings me to my dilemma. I've removed all the bolts and set screws, but found the shaft is pressed into the u-joint yoke and both bearings. I've attached a photo and am looking for some suggestions as to what kind of tools I may need to get this whole thing apart
