Hi all,
I'm stumped on something. Figured I'd ask a bunch of people who have a lot more experience with this than I have.
I have a '94 B7100 HST. I bought it last year, but have little idea when or how it has been serviced. So, I figured I should change all of the fluids and filters and grease all of the fittings I can find. I'm a bit confused about the fluid levels in the front axle and the hubs. The dealership could not give me a clear answer but said that I could use either gear oil or UDT. I did find this thread, which suggested to pour 0.7qt into the axle housing, and 0.15qt into each hub. When I drained the gear oil out, there was 1.5qt in the axle and 0.5qt in each hub.
Which set of numbers is correct? According to the markings on the filter, the transmission was serviced about 100hrs ago in 2008, and still seems to work ok. If the numbers in the forum were correct, is the excess fluid harmful? I replaced with UDT at the same volumes as were drained, but am open to draining some out if needed.
Also, I drained the transmission from a plug located at the mid PTO. There is what appears to be two more plugs near the rear axle (pic attached). There is one on each side. Do I need to pull these too, or is the same fluid I just replaced from the other plug?
Thanks everyone!
Thanks everyone!
