My small homemade wood splitter...
Alexisferos
L-1501 DT
Oct 24, 2013
245
Greece
This is a small (big) project that me and a friend of mine we started some time ago,
it has start with parts that we found for free, and later a full rebuild has been made to the engine, pump, hydraulics etc...
caterpillar hydraulic pump and hydraulics,
homemade tanks,
Opel 1.8 diesel engine belt drive the pump at half the engine speed,
Toyota radiator and hand made hydraulic cooler,
custom electrics.
Opel axle and Toyota rims and a lot of other small parts..
i will upload a small video later today.
i hope its a wannabe machine...
my small Kubota is like a dog happy when it carries the splitter and they go for work..
2,703
That is excellent work! With that engine, it ought to split the tree!!!!
I am curious what the fuel rate per hour is gonna be at 50% - it ought to have plenty of umf!
hodge
Nov 19, 2010
2,931
496
Love, VA
How fast does it cycle?
6,175
Nice, a lot of thought went into your parts assembly. How long of log can it split? Why did you have the line from the tank to the pump plumbed around the valve.... to keep a hose away from the engine?
CaveCreekRay
Jul 11, 2014
2,631
104
Cave Creek, AZ
Awesome job!
That is one monster splitter!!! GREAT use of available parts.
Good for you!
JackJ
BX1870-1
Mar 14, 2016
264
9
Indiana
Very cool! Just need to get a belt drive to a transaxle and a couple more wheels and you can drive it to the wood!
Alexisferos
L-1501 DT
Oct 24, 2013
245
Greece
thanks...
the fuel its very low because the engine works at low 1200 rpms for the pump to be at its full flow, but to say the truth i haven measure it, because it started like a hobby and then became a project.
the cycle is fast, i have i small night video that i upload right now at youtube.
this thing some times when i rev the engine it scares even me.
2 times i have destroy the knife at the end, it is just unstoppable at 4000rpm.
but i work it as you will hear near the idle speed.
@D2Cat i forgot to answer,
it can handle almost 1,1 meters and as for the hoses i have reroute them like this because even new they were free so i made the best of it with what i had, and the feed hose is like that for easy access to the drive belts..
hodge
Nov 19, 2010
2,931
496
Love, VA
thanks...
Can you provide a link to the youtube video?
coachgeo
Nov 16, 2012
2,460
37
Southern OH
might as well put a 4 way splitter on her.
hodge
Nov 19, 2010
2,931
496
Love, VA
Very impressive! It seems, by your description and the video, that it is almost too powerful for the build- you need to be careful with it.
Alexisferos
L-1501 DT
Oct 24, 2013
245
Greece
yes i know its a little bit overkill but when we started it was just a bolt on game of free parts..
olthumpa
L275
May 25, 2011
1,501
Maine
VERY nice work. It might have taken some time to build but you have something to be proud of. :)
3,709
HULLY JUMPIN JEZZUSE !!!!!:eek:
That bad girl doesnt even grunt,, I am impressed, yeah like somebody said time for a 4 way wedge for it,,, Ya done good my friend:D
Billdog350
Kubota L3710 HST,L2230A QT,forks,Takeuchi TB125, 60" Luck Now pto Snowblower
Jan 6, 2014
468
11
East Hampton, CT
Great design and project!
One suggestion, that 1.8l likely has plenty of hp/tq even at idle...rather than revving it up and running the belt reduction at 50%...why don't you flip it the other way and make it an overdrive? Eg. run the pump at 2x engine rpm. Then you can idle the motor, have fast cycle times, and you will lose just a bit of mechanical advantage so you don't blow the whole splitter up (do you have a pressure relief by the way?).
Alexisferos
L-1501 DT
Oct 24, 2013
245
Greece
Thanks for the good words,
can you plz explain what do you mean?
what like overdrive?
Tooljunkie
May 13, 2014
4,150
Engine gets big pulley and pump gets small pulley.
Engine at 1000 rpms will run pump at 2000.
Pressure relief regulates maximum working pressure.
