Hi guys
I used my slasher on the weekend but it didn't cut. (Pretty sure in the States you guys call them a bush hog)
I have a 26hp Kubota sunshine and was slashing in pos 1 at 540 with the throttle lever at 80%. I tried it in both first and 2nd gear but the grass wouldn't cut so I figure the blades may be blunt.
I raised the slasher to have a look and they certainly do not look sharp at all and the blades also have little nicks out of them. I bought the tractor with slasher a year ago and have no idea whether they have been sharpened or how old they are.
My question is, do I remove them and sharpen with a bench grinder, or does anyone leave them in situ and sharpen with an angle grinder?
I would prefer to remove them but I'm not sure how to. As you can see in the pics there is a central bar with the blades secured to each end. Do I take the whole thing down by undoing that large central nut, or do I just remove the blades. Is there a tip or easy way to remove them? It's a bloody large bolt.
Can someone also explain to me whether the blades are supposed to be fixed and not moving. What I mean is, does only the central bar spin rotate and therefore move the fixed blades? Or does the central bar rotate and the blades also rotate independently? I ask that because I can physically grab the blades with my hand and move them around 360 degrees. Are they supposed to do that?
Thank you
JC
Thank you
JC
