Ripper advi
Ruger.45
Illinois
I'm looking for some garden implements to work up our garden. It's in an old horse round pen from the previous owner, only flat spot on the whole 5 acres that's good for a garden. It has some serious compaction that I'm working with. I found a 5 shank ripper that's rated at 20-40 HP. I have a L225 that I think should pull it just fine or I may need to remove a couple shanks to get the depth I need in the highly compacted spots. What do you guys think of this one.
http://efarmtools.com/oakwind-products/cr-5-cultivator-ripper.html
2,970
If really compacted - I would go with something like this
http://efarmtools.com/oakwind-products/sr-1-single-shank-ripper-w-stand.html
or this :
http://efarmtools.com/oakwind-products/sr-1fp-single-shank-furrowing-plow-w-stand.html
but if you buy the one you mentioned - and remove the rest of the ripper teeth - and add them back slowly - you will have basically the same tool - all in one!
I would say that you will have to make several passes - but once your are done that tool will work well in the upcoming years!:)
7,299
If it's been a round pen it IS compacted. You need a sub-soiler of some sort. Cut the soil deep several directions to open it up, and work in any material you need. Probably has a lot of sand.
Ruger.45
Illinois
Nice job windzer! I see your in Illinois, I'm just south of Springfield, maybe I could have you make me one! I really like the 3 shank design!
I've thought about going with a subsoiler but these have 18" shanks and I would be able to use it for several other projects, where as a subsoiler isn't going that much deeper and I could always fab up a deep ripper shank and just use one shank.
windzer
Bx2370-1
Dec 8, 2015
82
Illinois usa
LOL small world I'm 15 miles south of Springfield myself yea I just used 18 inch box blade shanks for mine they worked out better than I thought I couldn't believed it pulled all 3 at full depth
