Changing to LED lights
billrigsby
Mar 17, 2015
1,050
247
Florissant CO USA 8213'
www.facebook.com
Has anyone changed Kubota OEM lights to LED. If so can it be done easily?
Define easily?
I have a L1500 with the old 3 pin mount motorcycle bulbs and at the time could not find "plug n play" LEDs
and my reflectors were so shot that after I did find one that would work it would have been worthless.
Other models have LED replacements.
I went this route
https://www.facebook.com/media/set/?set=a.1701495370119270.1073741863.1667881666813974&type=3
After the fact I found these, I think they would fit, but at $100.00 each, NO
https://www.allpartsstore.com/ItemDetl.htm?B2BSessionID=160401153930579&CategorySeq=S&SelcBrand=KB&SelcMachn=(Undefined)&SelcModel=VARIOUS%20MODELS&SelcSectn=LGHT&SelcSubsc=LGHT06&SearchItem=1&TextSearch=&ItemNumber=WL1116
https://www.allpartsstore.com/ItemDetl.htm?B2BSessionID=160401153930579&CategorySeq=S&SelcBrand=KB&SelcMachn=(Undefined)&SelcModel=VARIOUS%20MODELS&SelcSectn=LGHT&SelcSubsc=LGHT06&SearchItem=1&TextSearch=&ItemNumber=WL2116
So it depends on the model, if the headlights are original and what bulb they use
to determine if it can be "easily" done.
coachgeo
Nov 16, 2012
2,459
37
Southern OH
Search Feature is your friend. butttt...... I'll give you a pass this time :D... you can't search by LED. Too few letters
Hint. Moving this to the Fabrication/Customization forum where you can find alot of threads on this topic
hank2000
Kabota L3000F
Aug 27, 2016
81
louisville
I did. I changed my head light bulbs on my L3000F to led and all my turn signal and running lights to LED. Made a huge difference. Now that the factory lights are pulling less amps I can add my flood lights. lED of course
coachgeo
Nov 16, 2012
2,459
37
Southern OH
Your in KY and may be fine with LED head and flood lights. For folk who plow snow though.... they might have an issue. LED lights will get their light blanked out by a cover of snow where some form of bulb type light typically gets hot and melts the snow thus preventing this issue.
hank2000
Kabota L3000F
Aug 27, 2016
81
louisville
No or at least I didn't have to. I ordered LED bulbs from Amazon they were just LED'S with the same base as the old bulbs. Much much brighter
11,010
The LED not melting snow off is really more of an automobile issue, because the speed cools the lights off too much.
Most of the higher wattage LED still create enough heat to melt snow off on a slow moving tractor.
And it does take a lot of snow to completely block out really bright LED's. ;)
coachgeo
Nov 16, 2012
2,459
37
Southern OH
Most of the higher wattage LED still create enough heat to melt snow off on a slow moving tractor.....
Good to know.
tempforce
B2650HSDC
Jun 23, 2012
387
bastrop, tx
installed a pair of led bulbs to enhance my B2650's headlites. they made a significant difference. they were more of a blue than a white white. but they will work..
