Start with the easy things:I just purchased a B1700 and when you try to start it some times, it just clicks once and nothing..wondering why this is?
Buz
Before you do that you can try a few more things:You are saying take the starter to get checked? possible Solinoid maybe??
BUZ
The solenoid works by an electro magnetic switch which depending on the type of motor serves one or two functions.Terminals tight..and very clean..when you turn the key it just clicks once...haven't tried the headlight thing..but once you can get it not to click...it starts right up...no problem..not like a dead battery..
BUZ
yes, I have a multimeter..but you lost me on some things...I understand the workings of the solenoid...but not sure what you are saying on the copper contact moving?? Do you mean the wire to the bushings in the starter?The solenoid works by an electro magnetic switch which depending on the type of motor serves one or two functions.
One makes a ciruit between the terminal that comes from the battery to the terminal that goes to the starter motor windings with a thick copper contact .
The other moves a bendix gear driven by the SM into the ring gear to turn the engine
My guess is when you hear the click the copper contact is moving but only joining them together intermittantly so the contact is dirty,burnt or both .
You can test this your self,do you have a multimeter?
Tha solenoid is a high speed switch .Inside it on the other side of the two large terminals they have a flat surface,the copper contact bridges them together to get the power from the battery to the SM windings for it to turn.yes, I have a multimeter..but you lost me on some things...I understand the workings of the solenoid...but not sure what you are saying on the copper contact moving?? Do you mean the wire to the bushings in the starter?
I will give this a try Dave..thanks for the helpTha solenoid is a high speed switch .Inside it on the other side of the two large terminals they have a flat surface,the copper contact bridges them together to get the power from the battery to the SM windings for it to turn.
and this or the flat surfaces burn, I have taken many of these apart and resurfaced them to get them working again but it would not be classed as anormal DIY job.
I am not familular with your machine so will try to give you a generic test method
If your system is -ve earth......disconnect the -ve batery terminal then +ve battery lead and to sure,the other end of the lead at the solenoid and reconnect the battery -ve lead(this is for safety in case you short the +ve to ground with your wrench)
Connect and ohms meter between the two large terminals on the solenoid(one of them is one you have just taken the lead off)
Connect a piece of insulated wire to the +ve battery terminal (dont touch any body or frame parts) and touch the other end on the solenoid switch terminal. The solenoid should click..have a look at the meter for a low ohms reading.
If you do not get anything the contacts are not making contact and probably burnt.
dave
I just posted the same problem and then read this post. How does one use multimeter to check the soleinod?
Its usually a thin wire on the solenoid that is powered when you turn the key to the start position , when you power it from the +ve battery terminal it bypasses all other cicuites and switches including safety interlocks that prevent the tractor from starting when in gear or clutch pedal not depressed .Dave- could you please explain where/what is the solenoid switch terminal. is it one of the two large wire terminals?
thanks
Del
JWB, a bypass wire from the battery +ve to the solenoid switch wire terminal does the same thing if the main +ve battery lead is left connected but one has to be very sure the tractor is out of gear!Some of the kubota start switches go bad. They actually get loose on the back part of the switch. This causes the selinoid to no draw in hard enough to make contact. My l245 does this. I have to usually make it click three times before it will start. Try a remote starter button see if that works reliably.
JWB
