I have noticed play in the front driveshaft. At first, I assumed I had a bad u-joint. But after further inspection, there appears to be play between each of the 2 upper yokes and the splines. There is a little play at each yoke, which adds up when you factor in both on top and possibly both on the bottom. The yokes are held onto the shaft by a single roll pin.
Should I be concerned about this play? Is there an easy fix for it? The u-joints appear to be just fine. I assume I have the same issue on the lower end of the shaft as well, as the parts listing shows the same arrangement.
This tractor is built like a small tank, but I can't same I'm impressed with the front driveshaft arrangement.
