OK, on post #8 shows the new position of the fuses. I used the old holder because all I had to do is add some wires and ends and screw them on to the holder. Here is the new position of the regulator and the old fuse holder, just mounted it on the place where the regulator was, here are some pictures. Also had to replace old main switch, went down to the Case dealer and bought one of their switches for 38.00, has seven connectors and a key start. Here are the pictures of the new position of the reg. and fuse box. As for the temp. bulb, it rests right in the coolant, so, should register just fine, and I didn't use the drain anyway, just took the lower hose off to drain. Also, thanks for the heads up on the ultimate must reads, for the loader, thank you. Bob.
