I was wondering if I could get some help bleeding the fuel line on my tractor. It's a B9200D and I did read the operators manual on how to do it, but I wanted to check into something it said. Mine has two valves to open. From what I can make of it, you open the valve above the fuel canister first to fill the canister then close it. Then open the bleeder valve on the injector pump. However, mine does not have a decompression valve so the manual says to start the tractor for a minute while the valve is open.
Would the tractor even run with that valve open? And did I understand how to do this correctly?
