Thanks for the hints. My problem is packed snow more so than ice. The R4s and light weight tractor are a different adventure for me.You might consider screw-in carbide studs if you want a cheaper option than chains and guaranteed clearance. I use them in the R1's on my Farmall and the tracks on my T190 and it really makes a difference on icy surfaces. They take less than 20 minutes to install with a cordless drill. Removal is similarly quick when you don't need them. They don't give as much traction as chains, but they are much better than bare rubber.
Where are you getting the studs from and how much apiece? Every place I have looked, they are a dollar or more apiece. For me, this puts them in the price range of new chains.You might consider screw-in carbide studs if you want a cheaper option than chains and guaranteed clearance.
I have 2 link ladder style chains that came from my dealer as part of the package when I bought the tractor. Here is a link to some similar on www.tirechains.com. Mine are like the picture 2nd from the left.May I ask which chain pattern (ie. ladder, duo-grip, etc)
if you have the BH65 backhoe and 12x16.5 R4s, the right rear clearance is very tight.I also am thinking about getting chains for the rear tires on my B2620 and from what I can gather here.....I will NOT need a Wheel Spacer kit ?
genenj, I do have 12 x 16.5 R4's but I do NOT have the BH65 backhoe on my B2620 just a rearblade....so I should be okay ?if you have the BH65 backhoe and 12x16.5 R4s, the right rear clearance is very tight.
Been away from the computer for a while. Picture shows tight space between R4 and the BH65. Maybe an inch.genenj, I do have 12 x 16.5 R4's but I do NOT have the BH65 backhoe on my B2620 just a rearblade....so I should be okay ?
