I have a 2015 Kubota L6060 with attached Kubota 80 inch rear snow blower equipped with hydraulics for both Chute deflection and rotation. Whenever I activate the levers from the tractor for either chute rotation or deflection, rather than getting a smooth operation for deflection and rotation what I get is a very quick partial motion and then a lockup.
For example if I use the lever to rotate the chute it will extremely rapidly rotate an 1/8th to 1/4 turn and then abruptly stop and lock up. I need to back off the level and very slowly try again. Sometimes the chute will rotate a bit further and yet finding a solution. All hydros for the FEL work as expected. Could this be an airlock, could this be too much hydraulic fluid trying to push through to the chute cylinders? Do I need inline fluid restrictors? Seeking wisdom.
