Hi all,
Struggling to get new shoes for my B6100D
The specs call for:
Turf:
20.5 x 8 - 10 2PR in the front
27 x 8.5 - 15 4PR in the rear
R1:
6 - 12 2PR in the front
7 - 16 4PR in the rear
Currently, it has bigger tires ("turfish") front and rear installed:
23 x 8.50 - 12NHS 4PR in the front (Goodyear Soft Trac)
11-15LT in the rear (Firestone All Terrain)
I went in to see my Kubota dealer, and he recommended the tires that ship with the B2320HSD.
6 - 12 R1 Carlisle front
9.5 x 16 R1 Carlisle rear
The new tires come with new rims. It's cheaper than buying just the tires for some reason. However, the front rims wont work for me, because they are 6 bolt and my B6100D needs 4 bolt. I can work around this, because Kubota still sells the 4 bolt rims I need and they even have them in stock.
The new rear rims wont work either. The bolt pattern and hub spacing are correct, however the lug holes on the new rims are too big. They are 16mm holes vs 14mm lug holes on my current rims. My Kubota dealer can only supply me with 16mm lug rims - all the 16" 14mm lug rims are no longer available. I need to figure out what to do. I'm thinking I need to either:
1. Make/buy some 2mm bushings to take up the slop in the holes.
2. Find some other 16" rims that will fit my 14mm lugs and the 9.5 x 16 tires.
What have you guys done to replace the wheels and tires on the B6100 and B7100 series tractors? I read through a whole bunch of threads on here about people putting on new rims and tires (R1 and R4), and nobody has ever mentioned the 14mm lug size being an issue, yet Kubota can only supply me with rims that have 16mm lug size.
Thanks a bunch in advance for your help!
The specs call for:
Turf:
R1:
