Grouse Feathers
BX2370, FEL, Snowblower-BX5455, Homebuilt Forks, LP RB1560, LP GS1548
I thought I ought to try blowing snow at night before I have to blow snow at night. So it was time to test the tractor and cab under some night time conditions. Let***8217;s see dark and snowy night, 10 F, 20 mph swirling wind and 4***8221; of fresh snow (12***8221; would be better). Get dressed; worn jeans with hole in knee, snow boots, ball cap, shirt, and light fleece sweater that should do it.
What worked:
Lights - Two 27 watt lcd flood lights provide plenty of light for snow blowing. Brighter lights might be a problem with more light reflected off the swirling snow.
Heater ***8211; Maradyne 503012 piped into the cooling system bypass. I needed the fan on high to stay comfortable tonight. The other day blowing 10***8221; of heavy snow, the engine was loaded up and the heater put out more heat.
Defroster ***8211; The heater came with some hose that I attached to a 2***8221; pvc pipe. The pipe runs across the bottom of the windshield and has four 4***8221; slots cut with the table saw. With the heater blower on, the windshield stays clear and most of the snow quickly melts.
Snowblower deflector - In the woods with the wind swirling around I adjust the tilt of the deflector as often as I rotate it. In the dark you adjust even more to keep the snow plume out of the lights.
What needs improvement:
Back up light ***8211; The small 10 watt back up light is okay for backing up, but I need something brighter for using the rear blade. Will probably upgrade to a single 27 watt flood light.
Head lights ***8211; The head lights reflect off the snowblower and often the snow plume. This wouldn***8217;t be a problem, but at night it would be nice to have instrument lights. Resolved it tonight by turning on the dome light, I plan to unplug the head lamps. The cab mounted flood lights are much better than the head lights anyway.
Cold air leakage ***8211; I didn***8217;t seal up any of the floor or fender openings , and the only cold air I notice is on the back of my legs and seems to come from under the seat. I stuff an extra wool shirt behind the seat that blocks some of the cold air. I may look for a thin rubber mat or sheet to cover the fenders and seat opening, and cut slots for the levers and holes for the seat mount.
TJ you said you move snow wearing a snowmobile suit and a helmet. I would send you mine as a spare but I still need them for ice fishing. I will take a cab for blowing snow.
What worked:
