My new to me B7800 has 550 hours and is in nice working order as best I can tell.
The only mechanical issue I have is that the shift lever doesn't align with what is printed on the fender label. I'm talking about the (L-N-M-N-H) emblem.
When the lever is pointing to the Medium range, the transmission is really in neutral. It appears to be one notch off, and as a result, the lever hits the fender when all the way forward and won't fully engage into high gear. I have had it pop out of gear a couple of times because the lever won't go forward enough.
My first thought is the lever is bent, but an inspection of the lever doesn't show it to be bent. When it is parallel to the other lever next to it, they appear to be bent exactly the same shape. I removed the rear wheel to take a closer look and see that there are no splines on the shift shaft, just a single pin, so no adjustment that I can find.
Should I try to bend the lever towards the rear until the settings match up?
