I understand this is the same? as a L1500DT as far as the 4WD goes,
does anyone have this available in a PDF?
Thanks, Bill
Thanks, Bill
hmmm... is there something missing here? Don't think L225 is a Gray tractor. Well maybe the DT version???? but with the non DT NOT being grey?I understand this is the same? as a L1500DT as far as the 4WD goes,
Thanks, Bill
Not sure what you mean here?NIW has before offered to email a manual to someone maybe he has one still?
Sorry should have not used the abbreviations. NIW is Moderator/member "North Idaho Wolfman". There has been a discussion on this manual. A search should bring it up.... but of course now that I search for it here and with Google Advance I can't find itNot sure what you mean here? ....
Thanks, Bill
Got your PM and a have emailed you what I got.....
PM me your email address and I'll attempt to send you what I've got. It is the multi tractor version
PM me with you email and I can send to you this evening.Hi all,
I have just scored an L2000DT with a Gearbox issue. I have stripped the gearbox down and identified what I need to fix and have sourced the parts (after much searching). While I wait for the parts to arrive I would like to make sure I have everything else covered and need a parts manual. Can somebody pass on a pdf or let me know where I can get one. I believe after much reading and stumbling around in here I need the L225DT parts manual or L225 would do to put the box back together.
