Bent 3 point arm, and other questions B2650
wchp12
B2650, Landpride 60" RFM, CoutryLife 12" Post Hole Digger, Kubota BB60
Jun 22, 2015
19
Garnett Ks
I made the mistake of loaning my new toy (tractor) to a guy from work and when I got it back I found out he bent the adjustable arm, how I don't know and nor does he know how it got bent. What is the part called and who can sell me a new one (see picture)
Also a few other questions
1. What do I need to do to winterize my machine for KS winters? it will be stored inside my unheated and unisulated garage.
2. If I end up having to take the loader off for winter storage is there anything special with that?
3. Over the summer I had the loader off multiple times and it sat in my open air barn, 3 times the hoses were pressure locked when I went to hook them up, is this a common problem or what?
4. My tractor is at 45 hours and I know major service needs to be done at 50 hrs, what all needs to be done and how much is it going to cost me
Thanks
100 td
B21TLB (B21, TL421 & BT751) Toyota SDK4 T116 Bobcat
Aug 29, 2015
1,776
9
38
ɹǝpunuʍop
5 minute fix, pull it off and press it straight, and put it back. If you don't have access to a press, hammer it flat with a BFH!
bmblank
Mar 4, 2015
667
296
Cadillac, MI
You're going to need more than a hammer for that. If you don't heat it up red hot you can swing a hammer all day without getting anywhere. But yeah, you can straighten that up and it'll be good as new.
Sent from my XT1254 using Tapatalk
Diydave
L2202 tractor, L185f tractor
Oct 31, 2013
1,635
11
Gambrills, MD USA
I'd take that bent stabilizer off. and wedge it between the reese hitch and bumper of my truck, and take a cheater pipe, about 6-8' long, and bend it back to straight. Then I'd put the same bend into mr borrow-no-more's spine, with the same cheater pipe...:D:D
hodge
Nov 19, 2010
2,905
453
Love, VA
It isn't going to be "as good as new". It is weakened at that point, and likely to bend there again.
You would need to get that from a Kubota dealer, and they are called telescoping stabilizers.
Straightening it will work, but your friend should pay for a replacement. You shouldn't have to deal with a weaker component. Stabilizers take a lot of abuse; that was bent by compression, so he must have struck something with whatever implement he was using.
2,582
Thanks
wchp12,
listen to what HODGE is saying.....word for word......
He has been building these for a very long time, and if you ever had a turnbuckle style, you will understand how fantastic Hodge's stabilizers are built.
More on his second comment......your "friend" needs to replace it , period ....end of discussion - you would have to be thrown from the seat to do that - or have all tires spin against something "real"
3,449
Yeppers what hodge said,,, and your "FRIEND" should be paying for a new one,, with out question!!!!
Remember never ,never NEVER, let anybody else play with your toys,, err tools I meant tools.. UNLESS you go with them. I learned years ago to never trust a rear view mirror, a fart, or friends with my tools .
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,440
78
Rocky Face, Georgia
I agree with Hodge, it will never be as good as new without replacement. Your friend needs to step up and make it right.
Sometimes having a tractor can be a PIA. My equipment leaves the farm from time to time for other jobs but you can count on this, it comes with a operator which is me.
5,689
Yep, the guy using it should replace it.
Until then, take it to someone with a press and have them straighten it. Can't find one? Take it over to Parker. Machine shop on west end of Main St. has one and does good work.
2,582
GET SOME FUEL TREATENT FOR GELLING
NOTHING SPECIAL ON THE LOADER - MAKE SURE TO CAP OFF ALL OF THE HYDRAULIC LINES WITH THEIR RESPECTIVE CAPS
BEFORE YOU "UNHOOK" IT - CUT TRACTOR OFF - AND THEN MOVE THE STICK AROUND A COUPLE OF TIMES TO RELIEVE THE PRESSURE. SOMETIMES YOU MIGHT NEED A SMALL SCREW DRIVER TO "POP" THE END TO RELEASE THE PRESSURE - BE CARE THERE, COVER IT WITH A RAG AND TURN EYES AWAY .....
NOT SURE WHAT YOUR MANUAL SPECS ARE - BUT - CHANGE ENGINE OIL, FILTER AND HYDRAULIC FILTER, CHECK FUEL FILTER(S) AND CHANGE THEM TOO IF THEY ARE CRUDDY.......IF YOU DO THE TWO FILTERS AND OIL, AND FUEL FILTERS......LESS THAN THAN $50........GET A GOOD SYNTHETIC OIL MADDDDDE FOR DIESELS AND PLACE THAT IN YOUR MACHINE, OR USE KUBOTA'S OIL, BUT I WOULD USE ALL KUBOTA FILTERS NOW.......
hodge
Nov 19, 2010
2,905
453
Love, VA
Never trust a fart- made me think of this-
https://www.youtube.com/watch?v=il9Arcx4h2k
Now, back to the original programming.
5,436
Jeepers - I have a 16 year old son.
I always say there are no 2 funnier words to a young boy than FART and UNDERPANTS!! :eek:
They both make me giggle still!!:rolleyes:
