BX2750B Snow Blower Lube
abbx
mow, snow blow
Mar 16, 2015
41
High Falls, NY USA
Hello everyone, I got my snow blower mounted and working on my BX2200. It was tough AND expensive since my machine had no loader valve. My operators manual explains what to lube but not how. It says the gearbox oil level should be checked every month and 80W90 oil added if needed. I don't see a plug.
kubotasam
Apr 26, 2010
1,206
128
Alfred Maine
On the front of the gearbox. Part # 12 in the pict.
abbx
mow, snow blow
Mar 16, 2015
41
High Falls, NY USA
Thanks for the reply. The worm gearbox on my machine differs from the one in your diagram. Mine has a breather plug on top with a spring loaded cap. When I look in I can see the worm gear. Now my question is "how full should it be" Do I cover the worm gear with oil? Thanks again
Diydave
L2202 tractor, L185f tractor
Oct 31, 2013
1,635
11
Gambrills, MD USA
If it's new, make a note of the fluid level, or better yet, take a picture. If there are no leaks, it should be full. Take picture to service department of where you bought it. ASk them. If necessary ask them to pull the plug, on a unit on the lot, to see what the level should be.. You don't want to over-fill small gear boxes, fluid expansion will blow the seals, then you WILL have a leak...
kubotasam
Apr 26, 2010
1,206
128
Alfred Maine
The vent-fill plug is on the top. It still should have a level plug on the front of the box. Mine has a recessed hex drive plug about 1/2 way up the front. Take a pict of the front of your gear box and post it here.
OldeEnglish
Jul 13, 2014
768
Western, MA
Maybe take another look at the service manual, or look up the manufacture & model # of the gear box itself. I believe most require a half full level so that there is room for the oil to expand when it heats up, but I'm a firm believer on reading the specs because it may be different.
Both of the gear boxes on my snow thrower and hog don't have a fluid level port.
