Greetings y'all,
Nice to find this little piece of the internet dedicated to one tough little tractor!
I'm looking for a little or allot of advice on a project that I'm working on,
a '99 IH school bus that I'm converting to a rolling shop.
Why? It was cheap, $2500 on a mechanics lien, low hours and tons of room to do everything I can think of just short of getting a 15 liter suitcase in the back door, for now!
The 444 runs like a top but is a little to big for a power plant to suit me.
My wife and I are truckers, owner/operators with our own DOT / MC authority.
I needed a service vehicle that would encompass all possible needs without breaking the bank. I try to stay out in front of maintenance but it's just not possible to cover all the bases when you're a one man band. The baseline budget is $10k to get it all done but that's not written in stone.
I bought a seized D950 and 5kw gen head last week ($450). I'm going to rebuild it, block up (OEM parts) and install it side board under the floor. My estimate before tearing down the engine, replace crank,2mm over, boil block, new liners,pistons,rings oil pump. Rebuid head, cam, followers,injection pump and injectors, $2500+. I want to do it myself so I know this engine inside out.
I'm looking to run a 2 stage/4 cyl. Kellogg American air compressor off the front spline. 21" flywheel, 175 psi/ 25 cfm, 60 gl storage tank strapped to the other side.
http://www.globalindustrial.com/p/p...compressors-tools/two-stage-10hp-pump-l800004
Overkill? Maybe, but I want to run a 3/4" tire gun or my sand blast rig and or make enough power to run a Miller 212 or charge a battery bank.
I need to find a gear reduction box or pulley at a right angle that will take 1800 rpm of the front crank so not to over speed the compressor since it will be mounted parallel to the frame.
So far I haven't found one for 20 hp diesel application.
I'm not asking much! LOL
I do think it can be done, just not all at once.
If any one engine could do it all the Kubota would be the one!
Someone here must have tried something similar.
Any ideas or feed back is greatly appreciated!
I already know I'm mad but that's because I live in New Jersey and need to get back to Kansas!
