Making wood pellets
7,303
Yes, it is therm controlled, and auto starts. It's a Harman XXV.
I ran without an ignitor for a couple years. Much better with new ignitor in and working.
The stove has had about 70 tons through it.
5,166
They burned. They made heat. Need more.
Well that about pretty well covers it,, so now a visual episode of the rice and wet pellets
7,303
Gosh Frank, looks like they burn great. :)
You might be on to something!!:D
Tooljunkie
May 13, 2014
4,150
34
http://youtu.be/YBvCk2n1zz0
Last year's soy bean pellets. Flame is more orange compared to last one. Combine stopped for air in a tire, so i cleaned off the pile of chaff on the feeder house and stuffed it through mill. Stink when cooling, but solid pellets. Odourless after they dried.
Tooljunkie
May 13, 2014
4,150
34
Hey Frank how goes the pellet operation?
Ran off a few hundred pounds. Was planning one more test before winter but i have been struggling with my cranked back for the last few weeks.
Been a tough go trying to keep promises fixing vehicles. Its finally tapering off, hoping physio tomorrow will finally get a handle on it.
Next experiment is running mill slow. Slow as i can. Kubota wont cooperate at low rpms, it stalls. Going to fire up the old beast and idle it right down.
I noticed it makes good pellets at low rpms, but kubota powers out and stalls right when things start cooking along nicely, so i rev it up and then it goes out the window.
5,166
Just wondering how its going if your did the slowdown thing and how it worked out.. Or has the pellets frozen in to a big pile,,lol
Tooljunkie
May 13, 2014
4,150
34
Still suffering with my back issue, its all i can do to get through my day's work.
Found a gearbox in the shed i think will do the trick, hoping to get mill around 100 rpms with electric. This way i can plunk away in my shop where its warm and dry.
5,166
I hope your back gets well soon my friend I know that pains your putting up with
Tooljunkie
May 13, 2014
4,150
34
So, decided to spend a little time with pellet mill,added a gearbox and a 2 hp electric motor. Produces pellets slower but quality improved.
I also discovered the feed rate is where i was having issues.moisture that cooks out of pellets rise and steams the material above and tends to snowball.
Feeding slow enough to keep a small amount of chips to press reduces the accumulating moisture.
Building a hopper and 3-1/2" auger feed this week. Will post my results.
Also found a good source for wood chips, a ways away but quality raw materials to work with. Gentleman i met built an insane wood processor.
5,166
Well good on you my friend,, hopefully its almost over for this year and you can start on next years product,,,lol
Tooljunkie
May 13, 2014
4,150
34
Frank, I am mortified! I don't remember meeting with you! :D :D :D
Hes gunning for a 3 second cycle time with a 40" circular carbide blade. Block lands on a trap door and drops square into splitting chamber. Uses one joystick electric control. Almost has bugs out of automating most of the process.
Right now its turned down to run 7 seconds cut and split. Saw is 1/4 of speed capacity. Took a video but he requested i dont share it yet.
Tooljunkie
May 13, 2014
4,150
34
Pellet mill feeder pretty much completed, using a windshield wiper motor and pulse control. Lots of torque and delay should work perfect. I know need to make a video, but shop was tied up on weekend so couldnt crank up mill.
Video will follow soon.
