I jump started my L2250 and reversed the polarity now nothing works where do I start? Have a few fried wires.
well,
best start with every wire that is fried. Replace them and see if you can make anything work - fuses may be blown - take inventory on those too.
You will need a new battery I would imagine.........
in the future.....
jump start with tractor in Neutral.....make sure....even then lock the wheels with e brake if it works that way......
connect everything BUT the ground to dead tractor......
then find the magic spot on dead tractor and connect ground, hit the key then.
I real dead battery will not jump start well.
what you did is place a large amount of amps in the good battery running head on into the weaker amps of the bad battery.....somebody lost that fight!
If the wires and fuses are the only dead soldiers ...then count your lucky stars.....
my ex BIL had a mazda rx7 many years ago , bought a new battery from a local auto store....the terminals were CHARGED backwards.....when he hooked it up and hit the key.....fried every computer component in the system........ needless to say - the people at that store where in for a treat when the battery was placed BACK on the counter and the positive was not and the negative was positive.
report back on what you complete and what happens ...
sorry to hear of your bad misfortune!
