Fuel solenoid problem,
#1 check all fuses, under steering wheel left side.
#2 check connections to the solenoid (see pic)
If all looks good with those, and you don't want to play mechanic,
#3 if it's in warranty see if they will come out to fix it!
If you do want to play mechanic, remove the bolts holding the solenoid, remove it and it should start, Note to shut it down, push the lever directly above it or reinstall the solenoid.
I'll PM you (top right) with a contact info if you need immediate help in the middle of working on it.
