Hello,
I have searched the Forum and the Articles, but haven't found an answer to my question:
I will buy a B7001 in two week's at a local dealer. He is doing this business as an part time job as a full time farmer. He will get a delivery of a few tractor's. At what position's should I look to figure out, what's good or not. Are there some indications that are pointing to a deeper problem.
As fare as I know, I should check the following things:
All switches
All handles
All lights
Cooling and Oil
Sound of the engine/gears
The rubber of the hoses (brittle?)
The voltage at the battery with engine running (alternator?)
Oil leaking (sealings?)
Power of the hitch (hydraulic pump?)
Hitch keep lifted (hydraulic piston/valve?)
Everything screwed fiexed tide e.g. exhaust
Steering good (gears?)
Fuelfilter (broken?)
Airfilter (working?)
Can you add some hint's what should be checked (and why)?
Thanx for Your help
From Germany
Carl
maybe you can add somtimes a video at youtube, walking around a tractor pointing out where to look and why.
All switches
All handles
All lights
Cooling and Oil
Thanx for Your help
From Germany
Carl
