B1-16 Hydraulic Lift don't work properly.
traktor.com.pl
Rzeszow, Poland
Hello everybody, I'm new member of this forum.
I have trouble with my B1-16, the hydraulic lift don't work. If I start the engine lift arms go up, ther is no reaction on lever control, flow control valve under the seat also dosen't give any reaction (I can't push the arm down). In this model is electric control level and solenoid valve, I nowhere can find diagram or value to check. Maybe some of member can help me? Please.
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,434
78
Rocky Face, Georgia
I have to admit that I have no idea what a B1-16 is but I doubt it has a electric control on it if it's a B series tractor. Has this problem always been there or is this a brand new problem? On all the tractors I have fooled with the knob between your legs in front of the seat will lock the arms in the up position or simply control how fast they will drop when you lower them. Can you give some more info about what this is?
traktor.com.pl
Rzeszow, Poland
Thanks a lot for interesting. The model is Kubota B1-16DT BULLTRA, on frame I have number starts from B1600DT...., of course I have knob between legs and it's work but only then when engine is stop (I can control speed of drop) but if start engine arms alone goes up. I try to make photos of solenoid valve (controling lift).
KubotaTech
None- I get to play with everyone elses stuff
Apr 1, 2010
185
PA
Check to see if the feedback rod is adjusted correctly. There is mostlikely a small threaded rod attached to the hitch arms. This rod is what tells the hitch valve to raise and when to shut off. Back the rod off the whole way and see if the hitch still raises. If this changes what is happening to your tractor, raise the hitch the whole way up and adjust this rod until you have about an inch of freeplay. To check this, grab the hitch arms and pull up, you should be able to move the arms up about one inch.
cabu
Kuno B1-15 (B1502DT)
May 24, 2009
736
Germany, Oyten
cabu
May 24, 2009
736
Germany, Oyten
And by the way, the translation software for german on your shop-page is not good. A wood-chipper is not a helicopter, and so on.
If you like, I can have a look over it to make it a little bit more professional...
carl
traktor.com.pl
Rzeszow, Poland
Hello thanks for all hint.
Carl thank you for your links (photos were very helpfull to verification my system).
I check resistance in first, it' look good (it is range beetwen 0 - 5 kOhm) at two potentiometer. I check all the electric components and they are rather good, but arms dont work. I havent any manual (with this electronic) and I dont know how check electric valves. Have you any idea where can I buy this valves? (they havent any mark or name).
For example the Lower Right Switch = Monro Angle Adjustment
works ok.
Carl, thanks for your sugestion about our shop-page - actualy it was a Google-translation - I dont know German at all, I dont want take yours time but if you can look at this text it will be splendidly.
Wojciech
cabu
May 24, 2009
736
Germany, Oyten
hello,
befor you start to replace something, have you checked that the Selonoids (the coils of th hydraulic relay) get power?
Translating can be done in the next day's... :)
Have you checked www.Kubotabooks.com? Look for 1502 or 1600, they are nearly the same.
carl
Kubota 1400
Kubota Bulltra B1-17 and Kubota B1400
Dec 5, 2011
Germany
Hello, i have some problems with my hydraulic Bulltra B1-17 too :confused:.
Yesterday my hydraulic starts to make some problems. if i let it down and i switch the lower left switch in the mittle position (there is no function or i disconect the valve) the hydraulic lifts slowly up to the highest position. Is the valve damage or is ther any sealing ring damage???
Thanks for you help! carsten
Kubota 1400
Dec 5, 2011
Germany
Hello, i have some problems with my hydraulic Bulltra B1-17 too .
And yesterday i make some test and i found that my valve is damage where can i order a new valve with all parts inkl. but not the elektrical parts they are all ok.
kardspi
kubota zb1-17
Apr 11, 2021
corfu
hello fient
did you find the problem ?
odiekon
Kubota B 40
Apr 14, 2026
Germany
Hey! Just saw your pictures of the handle for the hydraulics of your tractor. I have a cubota b 40 which seems to have nearly the same hydraulics like your tractor. unfourtunabely everything controlling the hydraulics is missing on my machine. could you please give me some more detailled pictures of the handle and how it correspondents with the hydraulic-bloc? actually i´m totally lost an need a clue how to get this thing working.
Thank you and greetings!
10,622
The original poster has not been on for 16 years so getting any answers from them is highly unlikely.
The B40 is a very rare model and not much documentation on it.
I could not find any manuals.
Post some pictures on what you have missing and we might be able to cross parts to other models.
Send @cabu a PM he might be able to help.
odiekon
Kubota B 40
Apr 14, 2026
Germany
Hey!
Thank you so much for responding. I´m trying to talk to @cabu first.
