I have a B7100 that I bought new in 1992 with a fel. It has had quite a bit of hard use, tilling pumpkin fields. Leveling pads for buildings, lots of loader use, etc. At a little less than 1000 hours I had to have the top end of the motor rebuilt. Currently the loader bleed down so quickly you will spill your load within 10 to 15 seconds. The front tires are bald and full of plugs and slime. The steering gearbox is worn out but still working. I have lots of rear implements for this but don't know if they would work on a BX1870? I have a 48" tiller that is heavy for the B7100. I also have a 5' box blade that is a bit much sometimes for the B7100. I have an auger and don't know if a bx1870 could raise it high enough to operate. Then there is the question of ground clearance on the Bx. It seems like I might get caught up a lot. I got a cash price of $11,300 for the bx with fel.
I guess the question is should I spend several thousand to repair my B7100 or buy the Bx and sell the one I have? I just found this forum and hope that you folks can offer me your suggestions and advice on this matter. I would be great if I could hear from some Bx owners as I know nothing about them. I just happened into the Kubota store the other day and that's the first I've seen them.
