Operating the L3901
Brian526
2015 Kubota L3901 with LA 525 with QA bucket, QH15, RCR 1860, BB 1560, RTR 2064
Jun 27, 2015
9
Western Pa
Hi! This is my first post and my first tractor! So I am a newbie big time.. Have a couple questions...during my second time operating the tractor while using the FEL the rpm's dropped on me like it was going to stall then came back up...is this normal... Was operating/maneuvering the bucket both times... I did have a hydraulic leak I found this morning...I tightened up the fitting...seems to have stopped.. Also checked the engine oil and hydraulic oil..was fine.. Any input is greatly appreciated!!! Ty!!!
mdhughes
L3901DT
Dec 10, 2014
1,449
1,478
Ste Geneveive county, MO
Brian526, did you happen to lean to the right when the engine RPMs went down? The safety switch is under the left side of the seat and if you lean to the right too far it will kill the engine.
mickeyd
Mar 21, 2014
1,192
Guin, AL
Welcome to OTT Brian.
Brian526
Jun 27, 2015
9
Western Pa
I don't think....but I will pay attention to that if or when it happens again....Ty!
KennedyFarmer
L3901, with not enough attachments
Jun 8, 2015
289
Pennsylvania
i am starting to get a little annoyed with the operator safety switch. leaning to the right has got me a handful of times. i am all for safety but seriously did they think we weren't going to move in the seat?
BotaDriver
L3800dt
May 15, 2013
326
North GA
The one on my 3800 stopped working after hitting the 2yr mark. It is not missed. There is no replacement for good operating practices - and when such a device interferes with good operating practices, it's no longer serving its purpose.
zippyslug31
L3901, LA525, BH77, 72" BB, old Ford 22-63 PHD
Jun 27, 2015
82
Crooked River Ranch, Oregon
I've noticed the same sudden drop with my 3901. After I learned about the safety switch I now keep my butt firmly planted in the seat; don't believe it's happened since.
Rainy day project for me is to jump this switch so it's no longer an issue. I'm all for safety, but this is bordering on being too much a "nanny" device and is overly intrusive. If I wanted to be that safe I would just roll myself in bubble wrap and sit indoors. :mad:
yamatitan
L3901
Jun 28, 2015
38
Louisiana
It gets me all the time, when I first got mine a couple months I kept leaning over to see where my mower was and it would bog down. I thought the tractor was just stalling and thought it was a pos compared to my dads old kubota that would mow through anything. I finally realized it was the safety switch and its gonna get wired down pretty soon.
KennedyFarmer
Jun 8, 2015
289
Pennsylvania
I was thinking of using a shim under the seat vs bypassing the switch.
Not to mention it'd freeze up when below freezing out -- then the machine wouldn't run at all.
Freeze up did it get wetor wasn't covered?
RDL
39
Lowell,AR
My new L4701 was doing the same thing. I just bent the bracket down about 3/8 inch that pushes the switch-problem solved.
Brian526
Jun 27, 2015
9
Western Pa
Thanks for the great information! I ran it some today making sure I wasn't leaning and it ran perfectly fine... So I guess I chaulk it up to the safety switch on the seat also...I will definitely have to come up with a fix...because that can start to be a real pain in the dairy air!
zippyslug31
Jun 27, 2015
82
Don't think I'm following. You saying the L3901 won't run when below freezing? If so, me thinks you have another issue... pretty sure the tractor can be run in any 'reasonable' temp provided the warm-up procedure is followed.
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,434
78
Rocky Face, Georgia
I believe he meant the safety switch had froze up and would allow the tractor to start at all.
I would have to make that switch go away if it was mine. I like being able to start mine and then do a walk around inspection as it warms up.
I'm all for being safe but just because "Big Brother" thinks we need it doesn't mean that much. A perfect example of over doing it....Tier 4....Like we really need that crap. :mad:
sheepfarmer
Nov 14, 2014
4,438
678
MidMichigan
You can still start it and get off. It just kills the motor if it thinks the tractor is going forward without anyone in the seat. On the other hand mine was hard to live with initially because it is stiffer in cold weather (I think) and I couldn't get it out of the barn in the morning. Dealer fixed with a piece of cardboard.
5,177
Cplain that to me Lucy
__________________
sheepfarmer
Nov 14, 2014
4,438
678
MidMichigan
__________________
The basic problem was that dead center, even bouncing on the seat I wasn't heavy enough to convince it that it had a driver. There is a switch inside the seat itself that wasn't depressed well and needed a little help. After my butt warmed the plastic up the tractor would move, but those quilted coveralls made it tough. So a piece of cardboard inside the seat depressed the switch better, so no more problems.
