Yup, figured out which spider coupler I needed to connect the pump to the engine. Gonna need the 3/4" to 1/2". The same link I posted earlier has a mount that bolts to the four holes by the drive shaft to the hydraulic pump as well. Will have to call them for measurements of the bolt pattern to see which size I'll need to bolt it to the motor. So I've got it figured out what I need to attach the motor. Would just need to make a bracket to support the weight of the hydraulic pump. Hoses are no biggy. After the frame is built, then I can drag it over to McCarty hose in town and have them measure and make up the hydraulic lines. Pops has an old tank that's around the right size for an oil tank. Would just have to weld some 3/4 npt nipples to attach the lines and get a vented cap kit with the mounting plate. Kids getting married tonight so after this, I'll be able to get an electrician out to the house to get my sub panel straightened out and the welder hooked up. Had that project on hold till we knew what the wedding was gonna cost us. Then it's off to Lowes or tsc to get a bunch of pic's and measurements of a wood splitter to see how they did the frame and pivot Then to locate and gather up the metal and I-beam Should be able to get the axle locally.
