Hi.
I have a B6200D with a few slow leaks near the rear end.
I have attached two example pictures, although there are a total of 4 leaks.
In each leak instance the leak seems to be specific to one or two bolts (see circled areas in red).
I guess I am trying to figure out if this is common.
My wife, who I must shamefully admit has much more experience with tractors than me, says "It is a tractor, therefore it leaks".
The leaks are so little, I would say one drop every three days at each "Leak point", that perhaps it is considered no big deal, but....
The perfectionist in me says "leaks are bad" and "it was not designed to leak", therefore you must fix it.
Any thoughts or input? Are such small leaks expected? Is it "normal"? Is it worth the disassembly of the rear end? Etc?
Any input would be appreciated.
Thanks,
Jim
Thanks,
Jim
