So I just replaced the alternator on my L2201 and still can't get the battery to charge. I'm getting 12.5 volts at the battery with the tractor running or not. What else could it be? Voltage regulator? How can I test the regulator?
Im thinking a 12 volt bulb. Will see what i can figure out for a bulb.Ok. This regulator test requires removing a fuse and hooking up a 30 watt bulb. Is this just a regular house light bulb?
It seems like the new alternator did the trick. I ran all the tests on the new alternator and everything checked good, so I decided to check it out again once it was hooked back up. I ran the RPMs up to about 2500 and the voltage at the battery slowly started climbing. It was 12.5 not running. After about 30 seconds at 2500 RPMs it had climbed to 13.2 so I guess everything is fine. What do you guys think?
