Bx24 wont start
weberoje
Bx25D. Brush hog, Box scraper, garden rake, fork's, Front blade
Jul 14, 2015
9
Belfair, Wa
Hi all, I'm new to this forum. Sorry to ask this question I know its been asked several times before...BUT I have tried all of the suggestions ie...changed the fuel, new fuel filters, drain the tank, clean the fuel lines etc. it hasn't helped. I have almost 1000 hrs on my BX24. The problem are: It will turn over, if it barley start's it wont run very long once the key is let go of, it runs rough and dies. I have had many, many problems with my little guy, but all have been easy to over come. This one has me stumped! I'm thinking it might be Glow plugs but I need some help please???
Thank you for your time.
Joe:confused:
2,814
Joe:confused:
Have you.......
unhooked the fuel line past the pump and turned the key? Should shoot fluid a good bit......
Once you replaced all the good stuff - did you back off the bleed bolt and bleed the lines of air?
Have you taken a injector out and see if it squirts a good pattern......
coullllddd be injector pump......someone else will come along and run you a list of things to check ..........
weberoje
Jul 14, 2015
9
Belfair, Wa
Thanks for the quick replies. I will try these suggestions tonight and let you all know what I find out.
thanks again.
8,670
I'm going with fuel shutoff solenoid is failing. ;)
Tooljunkie
May 13, 2014
4,150
As wolfman said, fuel cutoff solenoid. Connecting a test light will tell you if it is activating, theres also a chance its not getting enough voltage to pull it open properly. Voltmeter would be necessary to determine that.
Bobsfixit
bx2350
Jun 13, 2015
21
Carmel NY
If battery voltage low not enough amperage to pull fuel shutdown solenoid out to allow proper fuel flow to pump
weberoje
Jul 14, 2015
9
Belfair, Wa
The stop solenoid quit working last night...no "thunk" when I turned the key on/off. I'll purchase a new one tonight and install it and see how it goes.
thank you all for your responses.
I'll keep "plowing" away!
Joe
weberoje
Jul 14, 2015
9
Belfair, Wa
:mad::mad:So if any one is interested, I got it to run but couldn't get it to stay running for more then 15 minutes...took it to a dealer and they say it needs a new engine. Blown piston. Any one know where I can get a new crate engine? been looking around and can't find one. Dealer want's only $5,500 to replace it for me.:eek:
