I have a Hydrotraxx marsh buggy with a Kubota D1105-TE engine. Just bought it used with 72 hours. I have a starting issue that is different than the ones described in the forum to-date.
Engine will crank, but won't start. Replaced the fuel solenoid, but still have to tap the solenoid or jump start the buggy to get it started...cranks right up when jump starting. Once started it runs perfectly and turns off normally.
Things I have done so far - replaced the fuel solenoid and checked the battery (715 cranking amps and tests good).
Any suggestions?
Any suggestions?
