I recently purchased a L3301 with a LA525 loader and BH77 backhoe. I am having trouble with my float position on my loader. My joystick clicks into position as it should, but when I move forward to scrape I loose my ability to steer because my front tires are being held a fraction of an inch off to ground my the loader. The tires make contact with the ground when I run in reverse. This is going to be a problem when I need to scrape snow this winter. My service man has been out and said everything is ok and that it is just the surface of my driveway. I tested on the flat asphalt highway in front of my house with the same result. I wonder if there needs to be some adjustments for the weight of the backhoe I have on the back? Any thoughts before I call the service man back out?
Thanks,
kulppac
Thanks,
kulppac
