TSC Subsoiler Modification
BotaDriver
L3800dt
May 15, 2013
326
North GA
The weak link of the TSC subsoiler is the 2 pieces of steel that run from the middle to either side on the back between the 2 3pt links. Those 2 pieces need to be reinforced. That's where they break :D
Post 2, pic 1 -- the piece that forms the hypotenuse--broke it more than once
atljetmech
B2601 w/ MMM & FEL
Jun 24, 2015
36
Ball Ground, GA
Thanks for the info. I'll keep a close eye on it during and after each use.
So far so good but I'm not using it a lot or real hard.....yet!
ShaunRH
L3200
May 14, 2014
1,414
Atascadero, CA
The receiver hitch kinda kills the pipe feed mod... maybe not, gotta think on that one...
Nice work, looks really good.
3,449
I don't think so a piece of square stock inside the hitch and a flat plate welded on the out by end and weld the J piece of pipe to the flat stock easy on easy off
ShaunRH
L3200
May 14, 2014
1,414
Atascadero, CA
Maybe. It might be susceptible to side deflection and bending but it might work with a guide welded on the back of the cutting tang to force it straight.
