BX-25 Hot Hyd.oil
Grouse Feathers
BX2370, FEL, Snowblower-BX5455, Homebuilt Forks, LP RB1560, LP GS1548
Feb 16, 2015
1,022
9
Lovells, Mi
Why do you ask? From the title of the post is your hydraulic oil hot? If so have you checked the cooling fan?
snowman1
BX25-Post hole digger-back blade
May 27, 2013
23
windfield pa
Yes I have , The fan is OK. I was using the loader the other day fixing washouts and when I was removing the loader ,The quick connects burnt my fingers. I never noticed them that hot before. I increased the Pressure from 1750 to 2000psi.
koja
BX25D
May 27, 2014
335
Fremont Mi.
Its normal . You should try touching the cylinders on case 590 super e after using it hard for e few hours .
5,475
Yes bumping the pressure up will increase heat. ;)
Hondahead
9
I have bought the shims to increase my hydraulic pressure. I just ordered one of each size shim available. Even thought I am probably just going to add .2 shim. Do you know why only the .2 shim has a hole drill through? Whereas the .1 shim and .4 shim are solid? Sorry if that is a silly question. I have not being through the manual fully or had the pressure relief valve apart to understand it yet.
