Hi I'm new on forum,and I love my B5100 and BX23 tractors.
I have a problem. A young neighbor came by to give me a hand yesterday, I am weak from a cancer and old.
While I was busy with a hydraulic hose at the vise, I said he could put the new battery in the BX23. When I finished the hose I tried to start the tractor.
It just cranked and did not fire, after a lot of checking of everything, I discovered he had put the battery in red on black and black on red. I switched it and the tractor fired right up, checked lights and all and all worked fine.
I took to the barn and turned the key to shut it down, it did not shut off. I even actuated safety switch's still ran. Finally I shut the fuel off and it shut down.
We discussed the problem and it sat awhile, maybe half an hour.
Started it again and it fired right up, turned off with key, all was normal, did this several times. Took it for a ride worked all controls, all is fine, brought it back to barn, turned key off it kept running, I had to cut fuel again.
Any ideas.
Any ideas.
