Recently my Kubota L-185 began to lose power. After troubleshooting, I determined that loosening the rear fuel line on top of the engine caused the engine to sputter and die. When I loosened the front fuel line, the engine idled a little rougher, but continued to run. A local tractor mechanic, after hearing the tractor run and my troubleshooting, told me that it was likely the front fuel injector. I decided to take a gamble and replace the front fuel injector, but instead of fixing the problem, now the tractor will not run at all. I then re-installed the old fuel injector and got the tractor to crank, but it runs worse than before. Does anyone have an idea of what I could do next to fix this tractor?
Thanks,
Joe
Thanks,
Joe
