Lift stops after about 30 min time
Kurtis01
Kubota L245 DT
Dec 15, 2014
Douglasville
Ok all new, hyd pump filter and fluid. After about 20 to 30 min time lift gets where it whines when i lift it. What could be my problem please.
2,550
What fluid did you place back in? weight of fluid? and IS there enough fluid there?
Kurtis01
Kubota L245 DT
Dec 15, 2014
Douglasville
Sorry was not thinking right it is a 1984 L245DT used tractor supply hyd fluid the one that everybody says they use.Super trac 303 hyd fluid. It is full and yes it looks foamy when i check the level.:rolleyes: thanks
Kurtis01
Kubota L245 DT
Dec 15, 2014
Douglasville
Sounds like hyd. system is sucking air somewhere. Check the hose that is clamped near the hyd. filter.
what all places should have a closed system so it can not suck air? When i got the tractor a couple months the pump and the housing under the seat had been off but they did not put gaskets back on if it takes them some has blue gasket gue around but no gasket but that should hurt with sucking air cause it draws fluid from the bottom. If im wrong please tell me. Thanks again:D
007kubotaguy
B7100DT L245DT JD 2355
Dec 23, 2012
642
254
Herald Calif.
Hello
The first thing to check is the suction screen . You will need to drain the hydraulic system first. The screen is
Located under the left foot rest. It's behind a cap that is held in with two bolts with 12 MM heads. Remove the cap and you should have a spring with a filter behind it. Remove the screen and clean. Good luck Lance
